Firmware 2.70 für StreetPilot III verfügbar
DesiWeb
Beitragvon DesiWeb » 23.05.2004 08:24
ich habe soeben auf der Garmin Homepage gelesen, dass es für den StreetPilot III bereits eine neue Firmware gibt.
Diese Version wurde am 20.05.2004 freigegeben - ist also noch ganz warm ;D
hier kannst Du die V 2.7 direkt downloaden...
Viel Spass beim Updaten!
hier noch rasch eine *mini* History:
Changes made from version 2.60 to 2.70:
Problems Corrected:
Recalculating a route didn't prompt for calculation method.
POI and waypoint symbols with a red cross were changed to use a blue cross to avoid confusion.
Corrected operation of the detour function, which was broken in version 2.50.
Features Added:
Added support for new features in the upcoming MapSource City Navigator release.
Changes made from version 2.50 to 2.60:
Corrected a problem where the wrong destination could sometimes be displayed after activating a saved route.
Corrected a problem where the serial communication format settings were not saved after resetting to defaults.
Corrected a problem that caused via points to be deleted when a route was recalculated using the route menu.
Corrected a problem where via points were indicated to be on the wrong side of the road.
Changes made from version 2.40 to 2.50:
Added partial route recalculation support.
Replaced French strings with new translations.
Fixed problem with MapSource halting when a route is transferred from the unit with the destination point deleted.
Fixed problem with Date field not showing the second digit of the year on the time tab.
so long...
herzliche Grüsse
Martin *TheRealSwiss*
